Old 09-23-2010, 12:46 AM
Default Re: Perry's Leimbach Build
I use two seperate 2700mAh AA packs, laying on their side - stacked up. The batt that runs the pump is always on top b/c I'll change that one 3 or 4 times to the other one that runs the rest of the model electrics.
You can't remove the hoses from the barb fitting, trim the hose with a sharp blade as close to the fitting as possible, if you ever need to remove. Then you'll have to cut the rubber hose that remains on the fitting.
