Old 10-31-2012, 12:50 AM
Jw.'s Avatar
Jw. Jw. is offline
Jw. is on a distinguished road
Default Re: 1/14 CAT 390D LME
Originally Posted by doodlebug View Post
Hey Jeff, thick and thin area's in a casting will alway's be a shrinkage problem. What I'm wondering is, can you cast the edge thick, and clean it up on a belt sander, to get the curved radius, on the leading and trailing edge? Just a brain cramp!
Cheer's, Neil.
Ah yes the shrinkage problem I designed my track pad and links .015" per inch oversize. To account for the 3/16" shrinkage per 12 inches for aluminum that I was going to use. Now though I will be using zinc, its 5\16" per 12 inches. So its now undersized just a hair.
About casting the edge thicker I think it might work but now you have to make sure you sand each leading and trailing edge on all pads to match each other perfectly so they mesh. That would be a job for someone with a really good eye and steady hands.
