Re: night hauler side marker lights
I have wired them into my Parking lights circuit, no relay required if you are using LEDS (Low curent Draw) so they can be run with the parkers. The other way is to wire them into the speed indicator lighting circuit, so they can be switched seperatly than the parkers, but the parkers will have to be turned on for this to work. Hope this helps.
Australian Heavy Haulage
"Keep on Truckin"
