Old 12-29-2012, 06:37 PM
woodhog's Avatar
woodhog woodhog is offline
Default Re: Building a trainer
Glad you got her goin For the lights you can use a battle switch or a pico switch i have bought several off ebay and they work perfect ! The radio will have a servo reverse to correct the steering ,also set your end points so the servo is not binding when you are at full lock left and right . You can also set your end point on the throttle so it won't be so fast . What radio did you end up with?
