Old 01-05-2013, 10:08 PM
PROBUILDER1964 PROBUILDER1964 is offline
Banned
PROBUILDER1964 is on a distinguished road
Default Re: gluing styrene to metal
Hello Dwayne When I want to glue plastic to metal I use the "CA" type glue....but you need to have the metal totally clean of grease and any kind of oils. Also ...here is the big clincher..... You have to rough up the metal really well where the glue will go....I like to use 80 grit sand paper or a sanding stick. roughing up the metal will help the glue adhere to it better and give the glue something to grab on to. Hope this will help ? good luck my friend....
