Thread: Knight Krawler
Old 01-11-2013, 07:43 AM
FlyingBeagle's Avatar
FlyingBeagle FlyingBeagle is offline
FlyingBeagle is on a distinguished road
Default Re: Knight Krawler
The chassis looks fantastic.
Does the lift axle have any suspension movement to it in the down position, or is it solid? I was just thinking if it is, you may have problems with bumps takiing the weight off of the drive axles and causing you to get stuck? I know in real life the lift axles are raised in rough terrain to prevent this, I just didnt know if yours was so solidly mounted to the servo that it may cause problems on relatively small bumps.
