Old 01-21-2013, 04:00 PM
Default Re: Aeromax AWD flat bed.
Originally Posted by woodhog View Post
Well what ya think of the axles?
Well after some tweaking here and there I took it for a test run and it did really good. The biggest thing would be rims for the front. You can use a round pin drive with stock front rims and you get a lot of turning radius with the same width as a stock front axle. I used a stock Tamiya inside rear rim with an extra bead glued on for super singles. To use the rims I put together I had to shave the steering arms a bit and use thicker hexes to widen it up a bit but I still ended up with the same track width as a stock axle. I did give up some turning ability with the SS but I like the look of them better so I gave up some function for style.
Travis
