Old 01-23-2013, 10:20 AM
Default Re: next truck project
It's not bad! Remove the rear part of the fender, and drop the cab down lower, either by cutting the floor out of it and making a new way to mount the cab, or else cut/notch the frame rails below the cab, to allow it to sit lower on the chassis. You could also raise the spring hangers and shackles. Maybe a combination of these things will give you what you are after.
