Thread: Relief valve
Old 02-16-2013, 11:55 PM
carp carp is offline
Default Re: Relief valve
Opposite end of the valve block to where your pressure line goes in, not sure what your valve is like but on the vario you have at one end a hole for the feed from the pump then next to that a hole that is for return to the tank, then at the other end you have the same i put my relief valve in there. I think there is a picture in the tech section somewhere of joes valve i will try to find the thread.
Edit: this is the picture i copied my setup from, post 14 by Joe http://www.rctruckandconstruction.co...ead.php?t=3697
