Originally Posted by Lil Giants
boom - throttle
swing - rudder
eleveron - stick
aileron - bucket
DX8 you are using? And what esc for the tracks? Probably best to use Aux 1 & Aux 2.
You putting an esc on the pump too? ch Aux 3 (should be the knob dial)
Instructions are nothing like Tamiya or wdc with any sort of detailed script or drawings, just some dark blk/wht photos & very little script... you're not missing out on anything.
Thanks Joe,
Yes I'm using a Dx8, I set up the boom, swing, stick and bucket per your recommendation. I'm not sure of the ESC that came with it, here is a pic.
[IMG]
[/IMG]
I've set up the two wires coming off the ESC as aux1 and aux2, and it drives with both tracks forward and backwards when I use aux1. When I switch aux2 on and off the right track drops out and it steers. Correct me if I'm wrong but I assumed on my DX8 aux1 would control left track and aux2 would control right track. Any help would be appreciated. As for the pump it runs continuos when the switch is on.
