Old 10-05-2010, 09:34 PM
Default Re: 2 IH 433 payscrapers (ps433-2 moves)
Originally Posted by trucker n View Post
man that is looking sweet steve
thank you tn
Originally Posted by dirtpusher9 View Post
Steve, you are moving along nicely. Will you make the St Louis show?
joe I'm coming but not enough time to get her running for the show my pump $ had to go else where but I should have it back soon .
Originally Posted by modelman View Post
IHbuilder-that looks really good! With it sitting on that trailer you can see the size of that "brute". Should be a "diggin" machine!!
thanks Tom . I'm hopping it will work like the real one . as is now it'll spin the wheels in the tires . I finally got the right size bar to make the wheels so I'll oversize the bead a little than stuff them . for size it's between a 627 and 637 cat . If you ever see a 627 on a trailer thats about what it looks like . But I think they have the 4th axle down .
Originally Posted by td9clyde View Post
would those be number 40 or 50 half links??? lol i know what those will be for i had to grind on mine to get them to work right and smoothly
1 more size 60 the pads will be 2" wide the same on my td8 wide track but much much bigger just a tad smaller than Joes D9 I will build the td8 also w/a 6 way blade just about got that figured out
IHSteve
