Old 10-07-2010, 01:37 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default Re: Cat 777D Mining Truck
Originally Posted by Iron Art View Post
Modelman, Those tires are looking good, I use a vacuum pump from Harbor Frieght and a garage sale pressure cooker as a vacuum chamber for moisture removal from Powder Coating powder, my thought is that would remove the air bubbles from the rubber. So far I haven't seen any problem with this lash-up. Fred
I have watched a few of vids on you tube and they all use vacuum for best results. Cheap way is to pour from a high height, 3 or 4 feet, that elongates the material and removes someof the bubbles. You have to have no air movement for this. I will try to track down vid I saw on this.
Awesome results for first attempt!!
