Old 03-20-2013, 04:52 PM
Default Re: Can drive motor affect steering servo?
W_E_L_L H_E_X_X!!!!!!!!!!!!!!!
Installed the external BEC and now the problem is NOT FIXED!!! Steering pulls left if throttle is above about 1/3. Works perfectly otherwise. Maybe I was too quick when I used the separate battery and thought it worked OK. Will retest and see what happens.
So back to the drawing board....
I'm going to try something I read in a Physics article about shielding magnets from electrical components. Basically it involves using an iron-based shield between the motor and servo. Simple to make and try. I'll see what happens.
I'll try to get a video up in the next several days. Wanting to finish the cab mounts so it looks like a truck.
