Old 03-29-2013, 01:58 PM
Ken Orme Ken Orme is offline
Ken Orme is on a distinguished road
Default Re: Straight edge cuts
I use a vertical band saw with a metal cutting blade on it. The metal cutting blade is tempered and has fine teeht. I cut alum, brass and copper. I found out the hard way not to try to cut steel with it, sparks will fly. I have cut square aluminun tube to make a special size channel. I either use a belt sander then files on a piece 2 feet or longer.
The trick is to use a metal cutting blade or a very fine tooth blade
