Old 03-31-2013, 05:24 AM
izzzul izzzul is offline
izzzul is on a distinguished road
Default Re: Custom-making SCANIA 8X8 Tipper
Wow, I like that. Very clean chassis, and well thought out plan. Your drawings look great too. I've never really seen anyone plan a truck build with drawings like that. What kind of transmission are you going to run? Modified Tamiya semi rear ends for the driven steer axles?
Using high-tork, low rpm geared motor, the same one I use for my RC Excav..for heavy Excav, i got hyd rotor/motor already..will replace that later.. and transfer case from RC4WD below...
and as for steer drive, you're right, mod the std one for now, trying the cheap way first, i got 1 set of 1/14 INTEGY full metal axles..but for now..
i hope it turn out to be ok..
