Old 04-03-2013, 04:30 PM
The pinion shaft on the gearhead is a solid 4mm, the bore of the pinion gear is 8mm. The hole you see, I just drilled that to pound out the broken pinion shaft from the steel bushing I made to mate the two. I also drilled two holes in the side of the steel bushing so the gear pinion set screws lock onto the output shaft.
