Thread: Unit Cable Hoe
Old 05-29-2013, 05:23 PM
SmallHaul's Avatar
Default Re: Unit Cable Hoe
With Spektrum, the rx's won't work simutaneously, a model change in the menu is necessary. Is the JR or Hobby King rx's any different.
The way i understand it, as long as the rx's are the same, you can bind an infinite number of them to a radio at one time.
In other words for example: you can take 10 ar6110e rx's put them all in bind mode and then hold the bind button on your tx and turn it on and it will bind to all of them and control of them at the same time.
Scott
"No load is too Small"
