Thread: odd schoolbus
Old 06-24-2013, 03:37 AM
Default Re: odd schoolbus
This weekend I received a little box with most parts I ordered
and I started to make it a rolling model.
the rims for the backaxle were on back order. so I used a trailerrim to get the tyre on, so I could get the floor level.
after checking, double checking, and triple checking.
the rear axle is 2 or 3mm to far to the back. and the body is 3 of 4 mm to low.
the axles are not going to be adjusted. the wheelwell is going to be ajusted. and there is going to be 3mm plywood added on top of the floor so the body sits a litte higher
