Old 10-21-2010, 07:59 AM
FreddyGearDrive's Avatar
Default Re: Manufacture Hydraulic Pump?
Originally Posted by Vanisle View Post
I hope they are OK. I just bought a couple recently, not yet received.
Richard
Richard,those pumps are ok if,your going to use on a dump or something that doesn't require the pump to run over a minute.I purchase a couple of them,& cooked one in a matter of minutes. If you read the spec sheet that comes with the pump.It tells you to only run in short spurts. One of them I modded to use a different motor,now it's perfect. Your still way ahead useing just the pump & changing the motor,vs $300 0r more.
It's all in what you want it to do.
I sure hope UMS does a better job gittin them to you,than they did w/me!
FGD
