Old 10-21-2010, 12:48 PM
dirtpusher9's Avatar
Moderator
Default Re: D9R and 463 pull scraper
Hey Ken, The o-rings are already sized, by that I mean that if you needed an o-ring for a 5/16'' shaft, it is made with the right tolerances that it needs to do the job. When I cut an o-ring grove I use the same tolerances.
The end cap and the large end are soldered, yes.
When do we get to see what you are building, Ken? It's been a long time.
