Old 08-11-2013, 11:38 AM
kingbob kingbob is offline
Default Re: Movie Optimus Prime build
From what I worked out, in scale it should be about 294mm tall ground to top of the roof. But the actual box should be about 200mm tall, which is how i've tried to size it.
I redrilled the mounts for the axles/suspension to lower the trailer, ended up with about 10-15mm between the tyres and floor of the box i think. Probably some variation due to construction thicknesses, but its within a few mm i think. In scale it should look "about right" lol.
The styrene sheets are by Evergreen, 12" x 24", so theres 2 on each side, glued together in the middle so the pattern matches, and trimmed to size. Cost about $18US each i think. I did find some local stainless steel with a pretty similar pattern, but was going to cost me too much, like multiple hundreds. Wasnt worth it. I have some chrome adhesive vinyl on the way to cover the styrene.
