Old 09-05-2013, 06:46 PM
Default Re: Tranmission E Maxx?
I have put the E-MAX trans in a Tamiya truck and had the front axle powered as well. It does fit well with just a little trimming of the trans or the frame, I just shaved a little off of the trans. On 7.2V with the biggest spur and smallest pinion the speed in first and second is acceptable. The biggest downfall is the amount of space it takes up in the cab. Now if you're planning to do this you will need punisher drive shafts and hardened pinions for the axles. It is your truck so build it how you want but I would recommend the RC4WD R2 2 speed it is a much better fit and it is super quiet.
Travis
