Old 12-04-2013, 10:24 AM
cosworth34677's Avatar
Default Re: diy hydraulic cylinders
well i made one. its work pretty dang good! in fact it bends the bolt it's mounted on when there is a heavy load in the dump bed.
the hard part was chacing all the leaks, and finding the right solder to braze it with. i found that so solder if its brazed once it turns super hard and you cant get it hot engh to take apart your part again. and brass is tricky to braze onto copper
