Old 04-21-2025, 09:49 AM
Default Re: TH407C Telehandler 1:14 scale
Very awesome to get to get to see this off the bench and moving!
Mmm, counter-steering. Could you set up a way to toggle a mix to also allow Crab steering?
If you don't have any tire scrub on turns, you're already doing way better than fullsize JLG bucket lifts
Old 04-21-2025, 10:50 AM
Blender's Avatar
Blender Blender is offline
Originally Posted by ddmckee54 View Post
Since you have a gearmotor for each wheel are you doing any mixing to get some differential action?
Originally, yes. Now I'm going to skip all together. Less wiring and the inner motor is able to bog down to match speed.
Crab steer is a must! It should be pretty easy to setup on the radio. It's the feature I look forward to the most when placing stuff with the forks. I'll do a front steer only as well for high speed travel.
Old 04-27-2025, 10:18 PM
Blender's Avatar
Worked on the tilt a bit. Had to turn a bunch of tubes from stainless. It was terrible, but I got it done. These parts were reworked from original design to accept Lesu implements. Less stuff I have to build and some commonality to my small wheel loader.
