Old 02-13-2015, 08:55 PM
rebelfox1985 rebelfox1985 is offline
rebelfox1985 is on a distinguished road
Default How To Question... Need Help
I am new to the truck building hobby and am in need of some help. I recently purchased the king hauler and i want to chop the sleeper to make it a true flat top. What do i use to cut the plastic with. i have seen some pics of one that was chopped and the cut lines looked like a perfectly straight cut. I used an x-acto razor saw and to be honest my lines no matter how hard i tried was far from straight... Any info will be greatly appreciated and maybe some one that reads this has some photo's or a site that explain's the complete process.
Old 02-13-2015, 11:03 PM
Default Re: How To Question... Need Help
http://www.rctruckandconstruction.co...isplay.php?f=5
Old 02-14-2015, 07:35 PM
Lmackattack's Avatar
I prefer to place tape around the sleeper and use this as a guide for my cut. Then a thin cut off wheel with a dremel tool to cut the roof off. After its cut use a small palm sander or file and smooth out the cut line. . Do the same with your roof. After you get smooth straight cuts glue the roof back on and glue supports on the inside for added strength. I use tamiya putty for the body filler and then high build primer after it was sanded.
Old 02-15-2015, 12:35 AM
bigford's Avatar
bigford bigford is offline
Best thing to do is cut the whole sleeper off and call rick @ pmd and buy a wedico sleeper and be done. Nicer box all around
Just saying
Old 02-15-2015, 05:44 AM
kingbob kingbob is offline
Really i think it comes down to what tool you're most comfortable with using.
When i cut my last King Hauler body up, i actually used a scribing tool. I found i got better results than using a saw blade.
Old 02-20-2015, 10:08 PM
but can i paint it the color i want beings it is powder coated
Old 02-21-2015, 03:29 AM
Dreamweaver's Avatar
Weaver Of Dreams
I use Thread.. Upholstery thread is best. mark your lines and then just go at it slowly.
To do this drill a small hole just big enough for the thread on the chop line. thread the Thread through the hole and then just saw with the thread. I leave the thread attached to the roll, this helps give you a good grip on one side plus the thread gets clogged and you will need to pull more through occasionally.
Mike "DREAMWEAVER" Johnson
