Old 12-07-2016, 06:08 PM
crusher's Avatar
crusher crusher is offline
crusher is on a distinguished road
Default Have tried everything i can think of
I am building my first build, it is a cat 330b exc. I purchased a new os 560kv motor to drive the hyd pump, I also purchased a new 90amp yep esc. I cannot get the motor to run. I have the esc hooked into channel 8 on the receiver. When power is on the red indicator on the esc lites up but no movement on the motor, I have channel 8 activated with a switch on radio. I tried an ohm meter across the motor leads disconnected from the esc all seem to have about same reading. I also purchased the set up card for the esc. The only setup instructions I can find on the net are for either heli or plane. I used the plane setup.
I have run into a deadend, any help or suggestions would be very welcome.
Thanks
Terry
