Old 01-07-2017, 01:01 PM
Just_Build_It Just_Build_It is offline
Just_Build_It is on a distinguished road
Question AT9 Radio setup ?
I recently got a RadioLink AT9. I have it all set up with throttle, steering and 5th wheel unhooking servo working great. Now my question is on the (ch3)throttle stick it is mixed with channel 6 up and down and left and right operates ch.4. The opposite stick for steering operates only channel 1 left an right, up and down operates ch.2. How can I have the throttle only operate ch.3? I'm probably as confused as you are while trying to follow me. The truck lights will turn off if activated when I flip the transmission switch also.
I would like to have it all operating properly but I don't know my way around this type of radio setup. I would greatly appreciate your help. Thank you and I'll answer any questions the best of my knowledge.
Here's list of my channel set up:
Ch.1- steering, left and right, right stick
Ch.2- not used up/dwn right stick
Ch.3- fwd/rev(up/dwn) left stick
Ch.4- not used (left/right) left stick
Ch.5- not used, 2position switch F
Ch.6-not used but paired with ch.3
Ch.7- blank
Ch.8- lights, switch H, momentary switch
Ch.9- transmission, 3 position switch E
Ch.10- blank
