Go Back   RC Truck and Construction > RC Truck's Defenders of the land. > Tanks!
Tanks! If is has Tracks it goes here..
Old 07-31-2017, 04:05 AM
Northern Farmer's Avatar
Exclamation Hengkong 1/8 All metal Tiger I RTR
Wanted to share this awesome tank with you guys. Weighs in at 60 kilos
https://youtu.be/Rh1VXLMoUtk
http://www.ebay.com/itm/HengLong-Hig...3D112444533914
Exclusive model of the tank!
It is delivered under the order - the delivery time is 2-3 months
The radio tank Heng Long German Tiger I is a detailed copy of a real combat vehicle equipped with a pneumatic gun for firing plastic balls. The control of the Tiger I combat vehicle is well thought out, it can completely rotate around its axis on the spot. The tower of the tank Heng Long German Tiger I rotates 360 degrees.
A distinctive feature of the radio-controlled version of Tiger I is that it is completely made of metal. The tank is made specially for the client with a unique serial number and an individual certificate.
The body of the tank Tiger I is made with high detail. It mounts attachments, a pneumatic cannon shooting balls, it can also reproduce the roar of a motor, a cannon shot, machine-gun fire, smoke comes from the silencer (oil is pre-poured).
The tower and the movement of the radio-controlled tank Tiger I can be controlled simultaneously. As a result, the actions are more realistic.
Specification:
Rotate the tower 360 degrees;
Raising and lowering the gun;
Before the shot, the warning indicator lights up;
On the control panel there is an element signaling the battery discharge;
The arrival time of the radio-controlled tank Tiger I is 30 minutes;
It takes about 6 hours to charge;
Control frequency 2.4GHz;
The capacity of the battery is 24V 27000 mAh;
In the package there is a charger to it;
Packing: quality wooden box.
Characteristics of Heng Long German Tiger I:
Dimensions: 104.2х47х37.5 cm,
Packing dimensions: 113x58x57 cm,
Weight: 60 kg.
