Old 12-02-2013, 08:16 PM
Default Gravel boxes for your King Hauler
I am almost ready to send these out to be powder coated so I thought I should post up some pictures and provide a little explanation of what you would be getting should any of you choose to buy one of my kits.
The price on these is $725US each, plus shipping. To calculate shipping cost, my postal code is V9Z0K5. When packaged, one box weighs just under 3kg and the box size is roughly 50cmx29cmx24.5cm. I may consider doing some custom boxes or modifications but that can be discussed with the individual if the need arises.
The boxes themselves are hand made, all aluminum and are TIG welded together. I press out the sides of the box but that is it. The rest of the pieces are cut out, bent in a manual brake and individually hand fitted before welding. I have been messing around with a couple of different cab protector designs but generally this is something that isn't too difficult to change while building to meet what the customer wants. Of course every time I build something new it takes more time so it may increase the price slightly. Tailgate latches are mechanical therefore they do not require any wiring or extra channels on your TX/RX.
The frames and drives are made up of a few different machined aluminum pieces and are bolted together.
The screw drives consist of a small 6V gear motor and a piece of ACME thread. I use ACME thread not only because it is more course to speed up the dump speed but it is also stronger and the square cut threads shoulder a load better. The down side is that it is much more expensive than going with a normal NC type thread. I am not running limit switches on the shafts so some care and attention will have to be taken when reaching the limits of travel in each direction. I may decide to add these at a later date but for now it seems that most of the people I have spoken with don't find them necessary.
I have installed this kit onto my own KH with only modifying one cross member(you need to remove the rib on the one ahead of the X member). The "prop rod" fits between the X member and the modified cross member. If you are running aftermarket frame parts the kit may not fit "as is" and will most likely need to be modified. The rear hinge mounts using factory holes and the rear bumper supplied with the kit. You must provide an ESC and be able to solder your own wires to the gear motor. It should also be noted that you cannot mount your battery between the frame rails behind the cab as it will most likely interfere with the prop rod.
After that long winded explanation, here is what I have nearly completed on the bench...
The one in the middle without side boards is the same as what you see on my KH with the exception that I have reduced the rear overhang by 1/2". It fits a stock height or slightly raised(1/4") cab.
The other two are virtually Identical to each other, and have a slightly higher cab guard(different shape too) and side boards. All three use the same frames and drives.
The undersides will be finished like on my KH.
Here's a short video from today.http://youtu.be/rm0lg49uiaI
If anyone has any questions or comments please let me know!
Thanks, Reg
