Old 01-05-2021, 10:26 PM
cooker2003 cooker2003 is offline
cooker2003 is on a distinguished road
Default John Deere 9 Series Tracked Tractor with Planetary Steering
Hi guys,
Inspired by our on-farm 9510RT, I've begun designing a 1/16 scale remote control 9RT. I really wanted to do it the "right" way with real double differential/planetary steering & it is even better than I anticipated. Steering control is very precise.
Features so far:
- True double planetary steering
- Continuous rotation GoBilda Speed servo for precise steering control
- Brushless sensored 540 1800Kv motor for unbelievable torque & smooth control
- All metal Actobotics gears & shafts
- Fully designed and 3D printed, less the hood, cab, and tracks.
Tractor is currently in 9300T form, but I'm working on the components to create a newer 9RT.
I have a sound module on the way also.
The 2700 Ripper has a servo to control up/down movements. I'm hoping to replicate a decent sized Deere 2660VT variable intensite tillage tool to go behind the tractor.
Quick progress video here: https://youtu.be/CkZ-da93lEI
Solidworks design of the differential steering and drive gears:
Some mini-lathe work to create adapters for the planetary sun gear. I found these planetaries on eBay as part of a brushless gear reduction motor.
Early design of the small planetary assemblies, modified to accept a ring gear for the steering.
All parts use M3 fasteners and heat-set inserts. Sealed ball bearings throughout.
Since the base 9300T that I sourced the original cab, hood, and tracks from hasn't been made in 20+ years, I had to soften the tracks in a mixture of boiling water and wintergreen oil. Worked very well!
Final iteration of the track frame assembly. Has functional track tensioner & walking beam articulation.
Cheers!
Dave
