Old 02-24-2011, 02:03 AM
aseejr aseejr is offline
aseejr is on a distinguished road
Default Futaba FASST Radio
Just thought I'd share:
Was testing Futaba 2.4 FASST radio, specifically the 7C Heli (only because I have them already). You are able to operate multiple receivers (I am using R617FS) all at the same time on the same transmitter (after binding them of course).
I tested 2 receivers with a servo plugged into each receiver on the same channel. Move the transmitter stick of that channel both servos move.
My thought now is on a build, you can place 1 receiver on the truck and 1 receiver on the trailer, bound to the same transmitter. You can mix functions / channels between the two units. Say using 4 channels on the truck and the other 3 channels on the trailer, without running wires between the two units.
I that came out clear.
