Old 08-14-2010, 10:33 PM
dirtpusher9's Avatar
Moderator
Default Dozer wiring diagram
Mike made this for me when I was building my dozer. It is a basic wiring diagram for wiring a dozer up. Thought it might help someone.
Old 08-14-2010, 11:30 PM
Roadmasters's Avatar
Moderator
Default
Cool, it seems way more complicated when you see it in the 9!!
Arioch
Old 08-15-2010, 12:12 AM
Default
Joe thats 1 of the things I have from a distant memory . It was a great help In under standing the basics for my dump . now I'll tackle it all
IHB
Old 08-15-2010, 01:04 PM
td9clyde td9clyde is offline
Dozer Builder
Default Re: Dozer wiring diagram
that would work for mine too only i have 2 esc's ..........anyone have a wiring diagram for a scraper????lol even though i don't need one yet :P
Old 08-15-2010, 03:54 PM
i'll give you a hand when your ready i got mine figured out just got to get it together and try it
ihsteve
Old 08-15-2010, 08:15 PM
Moderator
ihsteve
VIDEO?????????????
Old 08-16-2010, 08:52 AM
Originally Posted by dirtpusher9 View Post
VIDEO?????????????
I'll put the 1 I have up It's just photo bucket 1
IHB
Old 08-16-2010, 11:09 AM
JAMMER JAMMER is offline
Joe thank a lot I may need this. Ed
Old 08-17-2010, 09:30 AM
Has anyone tried a system that runs the hydraulic pump only when hydraulics are activated? Seems that some machine types (dump trucks, dozers?) would not have to run the pump all the time, saving batteries and reducing heat buildup in the oil. I was thinking about the hyd pump from India that seems to work best if run intermittantly.
What about running the pump with a motor ESC so hydraulic speed could be controlled easily and only run when needed?
Since I don't yet have any experience with RC electronics, don't know if these are viable alternatives or not.
Ken Sharp
Old 08-18-2010, 12:40 PM
CatdrvR's Avatar
CatdrvR CatdrvR is offline
CatdrvR is on a distinguished road
Ken, I remember looking into just such a device and remember finding one. For the life of me I can't seem to recall who made it but I will go through my archived information and see if I can track it down. It did exactly what you described, it would only turn the pump on when the valve servos were activated. It was quite the gizmo and I am sure saved a ton of wear and tear on the pump system and battery.
Dan
Old 09-09-2010, 05:56 PM
I have a relay that runs an air pump to build air and then it will dump the air. Ed
Old 09-10-2010, 02:21 PM
If I'm not mistaken, just about all the higher end computer radios can be programmed to mix any number of channels, so you could actually set things up to turn on your pump, when you start working the channels assigned to run the hydraulic valves. At neutral positions, the pump could be off. And I also remember there being a switch for sensing the need for hydraulic flow too, but I'm not sure who makes it. I'll bet Joe will chime in and tell us.
Old 09-10-2010, 02:27 PM
pugs pugs is offline
Not sure how small it could be found in, but need a pressure switch that opens at your max pressure and a timer relay that is run by that switch which would set the delay for how long before the pump shut off. Might also be good with a small hyd accumulator to keep the pump from constantly turning on and off.
Or a small circuit board that would sense applied voltage to any of the spool valve servos and activate a timer relay to run the pump with a dwell to account for small pauses between movements.
Easiest would be a way to program the remote to turn the pump on when needed and delay turning it off for a few seconds after movement has stopped.
Jeff
Old 09-10-2010, 02:56 PM
And if you had a spare proportional channel on the radio then you could run the pump with an esc and have a knob or slider on the remote which would act as the machines "throttle". Could be at full speed for coarse quick movements or half speed for fine movements like fine grading work or something. and still have the pump shut down when not needed.
Jeff
Old 03-17-2012, 05:57 PM
Smokin Joe's Avatar
I built a timer circut for my motorcycle stop lamp that when actvated, the stop lamp blinks 3 times and then goes steady. I used a radio shack generic board and a socket for the timer chip.
Source-http://www.allaboutcircuits.com
Old 03-17-2012, 08:42 PM
titandigs's Avatar
Aussie Fabricator
In my four hydraulic models I have the Servonaut BMA, its an off the shelf pump timer.
The servo leads from the valve servos plug inline, very simple and works well. As soon as you activate the servo the pump will start and after your last input on the stick the pump will stop after a few seconds.
Paul
