Old 06-10-2012, 12:02 PM
RD Trucking RD Trucking is offline
RD Trucking is on a distinguished road
Default Wedioc Loader Problems Hydraulic Pump
Hi all.
I am in need of some help with my loader
anyway basically all hydraulics stopped working other week.
so on inspection hydraulic pump was running and spool vales all opersting correctly. also check oil levels first off cause.
so i then moved onto filter which was ok.
then we check pipe from pump to spool and hardly any oil let alone pressure when put finger over end pipe so this lead me to remove pump and strip it down.
on inspection it looks like shaft from motor through into gear inside pump has worn out splines so slips on shaft under any tipe load, so looks to me a new pump is needed as im guessing no parts are avaliable for them,
so any help locating a pump supplier would be great help also if you know of a better pump for these loader maybe good option.
thanks in advance Gareth.
