Old 11-18-2010, 02:03 AM
aseejr aseejr is offline
aseejr is on a distinguished road
Default Tamiya Semi - Powering the Steering Axle
Can a Tamiya 3 Speed transmission out of a High Lift F350 be used in a Tamiya Semi Truck (King Hauler)? I know gear ratio's are not the same. The F350 has higher gearing (less torque).
Can a Tamiya front axle out of a High Lift F350 be used in a Semi Truck (King Hauler)? Does it have the same gear ratio as the semi's stock rear axles?
What I'm trying to do here is, getting the steering axle of the semi to pull as well. What is the best way to doing so?
