Old 02-10-2015, 04:37 AM
Roundabout Roundabout is offline
Roundabout is on a distinguished road
Default all dressed up and nowhere to go
You know the feeling when you get a little carried away when ordering parts, got this in the post today, 2,7 kilo around 4,5 pounds of aluminium, and I still haven´t ordered a truck for the parts, guess its gonna be a grand hauler.
René
____________________________________________
Old 02-10-2015, 07:50 AM
flatdeck's Avatar
flatdeck flatdeck is offline
Default Re: all dressed up and nowhere to go
Been there done that...LOL
Old 03-11-2015, 09:46 AM
got a bit more in the mail box today
cut the bunk, a did my first attempt at reshaping the fenders.
René
Old 03-11-2015, 12:30 PM
Chi-Noos Chi-Noos is offline
Chi-Noos is on a distinguished road
Is it just me or is that literally just a updated king hauler???
Old 03-11-2015, 01:03 PM
glorified King Hauler if you ask me Chi-Noos
René
Old 03-11-2015, 07:40 PM
I kinda figured that and agree just wasn't sure if they changed the body any.
Old 03-13-2015, 06:01 PM
got the front fenders glued in, and the rear of the cab closed up
René
Old 03-15-2015, 05:56 PM
got the inside of the fenders glued in, and a set of FULDA tires on my aluminium wheels.
René
Old 03-18-2015, 02:17 PM
got the gap around the fenders filled in, still a long way to go
René
Old 03-20-2015, 11:19 PM
Trucker_Jo's Avatar
Should look great! Good plastic work, Styrene is really great to work with.
Jarrett
Old 03-21-2015, 09:14 PM
Izzy's Avatar
Izzy Izzy is offline
Backyard enginier
Rene - nice fill work.
Travis taught me to take a seperately bottle of our styrene glue and put little pieces of styrene in it from our cutting and carvings. The pieces disolve and add filler to the glue. Helps fill moderate gaps.
Old 03-22-2015, 03:32 AM
thanks Trucker_Jo, it's more or less my first real attempt working with styrene
René
Old 03-22-2015, 03:44 AM
Thank you Izzy, as mentioned above, it pretty much my first real attempt with styrene, I got an old bottle of glue where the tube is broken, I'll try to put some of the shavings in it
René
Old 03-22-2015, 03:56 AM
Got a little more work done last night, cut a new frame stretched 6 centimeters or 2.1/4 inch, fitted aluminium rear axles, and a true scale dropped front axle.
first pic it got the tamiya front axle, and second one is the true scale dropped front axle
René
Old 03-22-2015, 07:49 AM
René
Old 03-22-2015, 10:15 AM
bunk glued, just need filler and sanding now.
René
Old 03-22-2015, 03:07 PM
thebat's Avatar
thebat thebat is offline
thebat is on a distinguished road
truck is shaping up nicely i want to do that frotn axle on my next build did you lower the rear of the truck too or leave it stock if lowered how did you do it thanks and any tips on making the sleeper the same height as the working cab keep up the great work
Zach The Bat Flowe
Keep On Rollin.
Old 03-22-2015, 05:42 PM
Thank you thebat.
I just cut the sleeper in four pieces, glued the sides together, and then I trimmed the top until i thought it looked the way it should
rear end is left stock, didn't want a truck that could run only with one trailer, tried that already
there are some pics in the link of my first King Hauler, stretched and dropped!
http://www.rctruckandconstruction.co...hread.php?t=85
René
Old 03-22-2015, 08:57 PM
thebat's Avatar
awesome thanks and thsoe trucks look sick as well one more question that i forgot to ask what do you use to cut the cabs up with will a dremel tol with a cut off wheel work okay or is there something better thansk again and cant wait to see how this one turns out.
Zach The Bat Flowe
Keep On Rollin.
Old 03-23-2015, 03:32 AM
usually I use a dremel, but for the front fenders i used a thread, drilled a little hole next to the headlight, put at thread through and pull it back and forth, it can make a pretty clean cut if you know what you are doing, mine was far from clean
René
