Old 04-22-2014, 06:07 AM
diesel950 diesel950 is offline
diesel950 is on a distinguished road
Default joining the globeliner gang
swapped a tanker trailer for an unbuilt globeliner
wanted to do something different without going overboard
cut a kinghauler grill down by removing centre section which fitted in the grill opening just needing to curve the opening to suit
next was the lights, wabting dual headlights i had a spare taillight bracket
and decided to use it when it fitted easily into the cab, just had to make lenses from clear plastic.
the chassis was cut down by around 10 cm but then added the rear parts from an aeromax.
the rear wheels are modified standard rims that i molded out of resin with chrome caps.
the cab was mounted slightly higher by putting cab mounts on top of the equpment tray instead of below
then it was painted in non-metallic colours and in a colour scheme of the 70,s to 80,s
to finish it off i used the small toolboxes from a knight hauler for the battery boxes behind the steer wheels with one of the large toolboxes mounted behind the cab.it has a set of mudflaps behind the steer wheels and an aluminium bumper bar.
also i modified the steernig with a longer arm on the steering servo,filing the brackets for the front shock absorbers for clearance and putting two small dends in the steering rod.
