Metal forming & tools If it bends,twists,welds,cuts & turns metal.Post it here |
Okay machinist, I need some help. I bought a 4-jaw chuck for my lathe since I need to turn round ends on some .125" square shaft. The chuck will only close to .250". Could the angled sides of the jaws be milled down to make the jaws move further in or are they hardened? I ran a file across the edge and it cut but I'm not sure if they are hardened.
If you cut them with a file you can mill them with a cold carbide cutter . If 2 piece you'll need to do both . The best solution would be a square collet if you have a collet chuck or nose .
Make some shims for the stock and fill in the gap with them!
Don't mess the jaws up! Cheers, Neil. |
I agree with Doodlebug.
Chucks are expenive. Use shims. |
Perhaps you can machine a set of replacement soft jaws yourself?
I have used penies for shims. |
Currently Active Users Viewing This Thread: 14 (0 members and 14 guests) | |
