Old 11-16-2018, 11:10 PM
igotit igotit is offline
igotit is on a distinguished road
Default Bruder D5 1 day build
ive been wanting a d5 build for awhile,but always forgot about it,or put it off.....ect.
we all seen em done before,nothing new right.
i chose the same tamiya 4 speed gearbox model 70168 as most do,but id went a different route with controls and the blade.....and the sprocket.
i installed a complete $50 heng long tank tx/rx/mfu system with sound and option to install lights later.
HL route offers 1 stick tracks,leaving the turret channel open for the blade.
and i have on the tx volume control,and the smoke button is on/off control that can be used to activate lights.......all for $50
i have no room to spare under the interior after installing everything.(speaker has been moved inside)
i went with 2 18650 samsung 25r 3300 mah lion cells for 8-12 hr runtime before needing a charge.place in a $3 ebay battery holder.
i designed and 3d printed some new drive sprockets with longer teeth.
also designed the servo post and pivot system for the blade.
i chose a standard futaba s3003 servo,ripped out the servos esc board and pot,modded for 360.....soldered on motor wires.
so my servo is basically a gear motor that looks like a servo.
when the blade reaches max travel it stalls the servo.
https://www.youtube.com/watch?v=66zd...0K9JdN_a6Mkqb8
Bruder d5 by Nick Pellegrin, on Flickr
