Old 12-23-2017, 12:22 PM
Default Rc4wd 870k wheel loader unboxing and review.
https://youtu.be/EBi2B8o7gTs
All the previous unboxing videos I've seen on youtube came with a nice wooden box. Wanted to show how the recently shipped boxes come now. Also notice the front bucket ram PIN is installed where as before you would need to put that on yourself.
Now the new foam box is very well packed as you can see in the video.
My initial reaction was, wow this is heavy, especially the rear end. That's probably why it has so much lifting power.
There is no sound module card (that's expected from rc4wd) but there is a speaker installed already with wires coming out from it.  So installing a card should be a piece of cake.
It looks very well built.  They revised the colors. The rear radiator grill and engine handle bars are now Gray instead of yellow. I think that really changed the way the machine looks.
I already filled it up with oil and started her up. The pump noise is much louder than my pc700 and cat740. The valve control is not that precise compared to my pc700 equipped with Premacon valves.
It's hard to describe but when you move the stick very slightly, the rams don't move and I can hear the pump noise struggling so slightly. If you move the stick a little more, the cylinders start to move but not at the expected slow speed you want. This is the same for all 3 valves. Full disclosure, I am running mobil dte24 (ISO 32) and when I asked around including Mr Tang from eagle, he said it will be ok as long as it's not too cold outside. I live in Los Angeles so I think I should be fine with that. Here is a video of the valve control. https://youtu.be/eyyLs9oaXl8
(Update to the above issue, I unscrewed the pressure relief valve maybe half a turn and that solved the issue above)
Now comparing to my pc700 or cat740, the stick movements reflect 100% on the cylinders movement as one would expect.
This review was based on 10minutes of run time. So I will edit as more running time goes on.
