Old 01-14-2012, 10:11 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default SW K100
I am epically slow builder. This project mostly sits in boxes, rather than on the workbench.
Nothing special about the chassis. Not sure I like the 4:1 so it will probably go in favor of pinion reduction.
First order of business was to get headlights. My K100 is later model, lets say 1992.
Next was the axle and lower cab "wheelwell"
I need some more clearance on the wheel so may have re-bend the spring a bit more or add spacer.
Filling the rear panel:
I think I may redo the rear cutout. One problem is I think its a little low. And second I bought a set of S&P sweet pipes that are so big they won't fit/hide under the short side skirts. The entire bottom edge may have to move up 1/4" or so. Not sure how I'm going to solve that one.
Starting work on the side:
Not much progress for the two years I've had it.
