Old 04-07-2015, 09:07 AM
trucklover trucklover is offline
trucklover is on a distinguished road
Default What esc?
Hey gents. What esc are you guys using for your dump boxes or screw drive tippers?
Old 04-07-2015, 10:03 AM
Default Re: What esc?
Hobby King has a cheapy that works well for less than $11US.
Old 04-07-2015, 02:50 PM
Thanks RCP!
Old 04-07-2015, 06:27 PM
ricm ricm is offline
I don't use ESC as you never quite get full power to the motor....I use a 2-way switch with H-bridge relay setup to get a direct connection to the battery....although a bit more complicated that a 'plug and play' ESC!
Old 04-07-2015, 08:42 PM
Sorry to hijack the thread but what one do you use Ric? Does it work with limit switches?
Old 04-08-2015, 07:23 PM
Here is what Izzy and I use. It is only available at servocity. It has built in solder points for limmit switches to limit travel in both directions. These have been very reliable and have not had one fail yet, very happy with them.
https://www.servocity.com/html/elect...lled_dual.html
Supply Voltage: 3.8-5.5 VDC
Supply Current: 20ma static, 75ma energized
Load Rating: 0-30 VDC at 12.0A
Switching Time: 7.0 milliseconds
Switch Resistance: .012 ohms
Dimensions: 1.85”x2.70”x1.10”
Weight: 1.4oz
