what is the right way to figure wheelbase?
axle nut of the steer to axle nut of the last axle on my wrecker it is 25'' and when I scale up I get 29'2'' or 350'' im thinking I could go longer for the wrecker |
Thats the way I would work it out ctr front axle to ctr rear axle
As over all length would be front of the vehicle to rear of the vehicle Cheers Tracy
RIP FreddyGearDrive 2-12-59/12-19-11 Love my Kenworths To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
I could be wrong but I think it is measured from the front axle to the center on the tandems(trunion). That's the way it was measured on the 850 KW's anyway. I thought it was measured from the front to rearmost axle and had to redo my frame length twice because it was too short!lol
Reg is correct, steer axle center line to rear suspension centerline.
so the rear leaf spring pivot nut
on a 3 axle semi tractor .....center of front axel to center of tandems.
MACK
"The Greatest Name in Trucks" |
what about with a lift axle in the mix?
The lift axle wont make a diference it is to the center of the drive axle or axles.
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
I could be wrong but I think you measure a wheel base from the center of the front axle to the center of the rear most axle. Ed
![]() ![]() Center of steer to center of tandems. If it were tri drive? I'm not sure. But likely still center of rear two axles.
I think it's confusing but it might help to look at this site, http://www.cdxetextbook.com/safetyIn...aswhlbase.html hope it helps.
Bo |
Bo they call that axle spacing
cabs
OK......so what is the difference ? they talk about wheelbase but mean axle spacing ?! even more confusing !? |
In the manufacturing arena, axle spacing would be the distance between the center line of the drive axles in the case of a truck and the "spread" of the axles on a multiple axle trailer. If you've heard of a trailer suspension referred to as a three nine, that just means 3 axles 9 feet apart. This used to be popular with steel haulers.
As far as what the DOT does...... well that's a whole new ball game ![]() ![]() |
There is a kind of explanation on the model magazine forum, scroll down 1/3
and look at the picture. http://www.modelcarsmag.com/forums/t...bius-lonestar/ It's funny to see that nobody or everybody knows what is the right or wrong method is ![]() |
I am not trying to spec a truck. Just wondering how and what rules there is out there. I am curious like bigford is |
"If it were tri drive? I'm not sure. But likely still center of rear two axles".
The wheel base is always measured to the center of the main drive axle suspension. |
