Old 08-13-2010, 04:39 PM
Tamiya Cowboy's Avatar
Default 5th wheel plate wrecker
I seen a 5th wheel EZ-Tow a guy built over on scale 4x4 and I ave wanted one for sometime so I set off to build one.
I started by making temp-lets out of oak tag and then traced them onto a piece of 1/4 alum plate and cut them out on my vertical mill "band saw" and then smoothed the edges up with a DA with 180 grit paper on it.
Then I drilled the holes I needed to bolt it together with and a hole pattern for so design other than blank rails.
Paul W. "Tamiya Cowboy"
Old 08-13-2010, 04:40 PM
Default
Next the pivot point was made out of left over chunks of box trailer rails. And then mounted to the main plate with the king pin in it.
Then I traced out and drilled bent and mounted the upright and also mounted the winch that will lift the boom.
Default
Old 08-13-2010, 04:41 PM
Default
Ok I got the draw bar built tonight as close as I could to the picks on there web sight. I built it out of 2 pieces of square brass tubing one slid inside of each other and then a piece of square key stock slid inside of the brass. Then I soldered 2 brass tabs on it. 4 chains 3 links long hook it to the tow arm and the rest you can see in the picks.
And here is the different ways they show on there sight to sling a rig.
Axle sling
Old 08-13-2010, 04:42 PM
Default
Front Axle Sling
The Frame Hitch
Old 08-13-2010, 04:43 PM
Default
Looks better on the Fruitliner
[/b]
Old 08-14-2010, 11:42 PM
Roadmasters's Avatar
Roadmasters Roadmasters is offline
Moderator
Roadmasters is on a distinguished road
Default
Very cool. I saw 1 on the road just a few weeks ago!
"My son will have a chocolate milk" -J.P.
Next East Coast Minitruckers Meet:
Arioch
Old 08-15-2010, 12:03 AM
Default
Originally Posted by fhhhstix View Post
That is a good alternative to building a full blown towtruck.
Hey thanks much guys it was a cool little build I have traded this off but I am planing on building another one this winter.
Old 08-15-2010, 10:40 AM
JAMMER JAMMER is offline
Thumbs up Re: 5th wheel plate wrecker
Paul as usual nice work. Ed
Old 08-15-2010, 12:12 PM
Default Re: 5th wheel plate wrecker
Wow. Your cuts look really clean for being done on a bandsaw. While it does look better on the Freightliner, wouldn't it be more typical for the Freightliner to need a tow? Just kiddin'!
Old 08-15-2010, 12:20 PM
ihbuilder's Avatar
hi nathan , hey isn't it supposed to be freightshaker
another cool build
IHB
Old 08-15-2010, 05:11 PM
Steve, I wanted was going to type Freightshaker, but didn't. You read my mind though.
