Old 07-17-2016, 09:50 AM
Alex39 Alex39 is offline
Alex39 is on a distinguished road
Default Hydraulic cylinders for rc construction models
What do you think about this cylinders?
http://www.ebay.com/itm/331910578727...84.m1555.l2649
Old 07-17-2016, 11:02 AM
bigford's Avatar
bigford bigford is offline
Default Re: Hydraulic cylinders for rc construction models
cant really have any thoughts, no real info is given
Old 07-17-2016, 11:21 AM
Dimensions is 145/230 mm, pressure 25 atm.
Old 07-17-2016, 11:44 AM
bigford's Avatar
is it double o-ring /what size it the thread for the fittings. they look real skinny
almost home made
Old 07-17-2016, 11:45 AM
bigford's Avatar
OH and your the seller
alex393939 (123 )
Old 07-17-2016, 09:57 PM
Cooper's Avatar
Cooper Cooper is offline
alex393939 (123 )
Alex, where are you from? And how about a pic of the insides? That is how I could tell you what I think of them. What a coincidence you and the seller have the same name!! Cool!! I'd say buy them just cuz of that!!
Old 07-17-2016, 11:06 PM
headers headers is offline
headers is on a distinguished road
Magom have some pretty good prices on their cylinders also
Old 07-18-2016, 03:20 AM
I'm from Poland.
I do not know how to explain the coincidence of names
I want to buy two cylinders for may KAT excavator and I wanted to ask whether the experience of the use of these cylinders is on the forum
Old 07-17-2016, 12:00 PM
You are not right.
I want to buy this cylinders for my KAT excavator
Old 07-17-2016, 12:54 PM
bigford's Avatar
if you have a KAT then buy the rc4wd cylinders they work great
video of the kat
https://youtu.be/1nSKkV7DrSA
Old 07-17-2016, 01:11 PM
But they more expensive
Old 07-18-2016, 04:59 AM
bigford's Avatar
I think there going to be as bad as the ones that come with the kat. Cooper built his own cylinders and gave
Me the Rc4wd ones.
Old 07-18-2016, 06:49 AM
I try to buy this cylinders
Old 07-18-2016, 06:54 AM
Doggy's Avatar
Doggy Doggy is offline
Doggy is on a distinguished road
Question for people making their own cylinders: What thickess do you use for o-rings? Or what do these ones on the market use?
Old 07-18-2016, 07:35 AM
Rimrock Rimrock is offline
Use 1.5mm thinkness (sometimes 1.78) for the piston and rod seals, 2 off at each location. To seal between the front piece that contains the rod seals, and the cylinder pipe I use also 1.5mm (x1) when enough space. sometimes need to use 1mm here if thigh space. The 1mm seals are more vulnerable for damage when putting the cylinder pieces together, so a more thick seal is better. One need to study the tables for seal groove clearances to get the correct size grooves etc. If one got a 8mm rod, one should not use a o-ring that is exact 8mm inside diameter, but better 7 or 7.5mm max to get a good fit.
Old 07-18-2016, 07:22 AM
See it's a new brand, GSK, from Kalinigrad. They are possible not known to anyone here at the forum yet. Great if you buy them and test them out and write a report here. It's positive they are from brass, not aluminium as some of the Chinese ones.
Old 07-18-2016, 12:54 PM
I'm wait new cylinders for my KAT
Old 07-26-2016, 12:57 PM
Today I received two cylinders for my KAT excavator from GSK Earthmovers.
Old 07-26-2016, 03:50 PM
what outside diameter?
Old 07-26-2016, 05:18 PM
12 mm
