Old 08-05-2016, 08:25 AM
Rvjimd's Avatar
Rvjimd Rvjimd is offline
Default Another Structo Dump Truck Conversion
I got a good start on my first dump truck yesterday. I'm try to use some of the drivetrain and suspension parts from a donor short course truck I had.
Just checking the edit function, I still need to find a new place to host and link my photos AND try to download all my photos from Photobucket...
Jim
Old 08-05-2016, 10:57 AM
Rvjimd's Avatar
Default Re: Another Structo Dump Truck Conversion
Starting on the front end, this might be harder than the read end, I'm going to try and make it a 4x4.
I thought this shot was worth the tall part in the mill vise clamping solution...
Jim
Old 08-05-2016, 04:48 PM
rc_farmer's Avatar
Master Builder
I remember that truck with the pneumatic cylinder, good conversion
Giving up is not an option!!!
Rob
Old 08-06-2016, 03:50 AM
That's looking like a really good start.. It'll be really interesting to see how your truck comes together.
What was the short course donor?
Old 08-07-2016, 08:53 PM
Rvjimd's Avatar
Friz, the donor is a dromida. I'm not convinced it will be the best donor, but it is what I had on hand. It is pretty cheap and mostly plastic parts like all the diff and shafts and stuff. It will be interesting to see how it holds up if I get it going!
Here is a related video I just posted about the gear head motor I am using in the truck. I screwed up and used a mounting screw just a bit long and it busted a tooth off one gear in the motor.
http://youtu.be/HsCEJ2fIEKM
Jim
Old 08-07-2016, 10:01 PM
Rvjimd's Avatar
Got some more done this weekend. I am going to have to fine tune the chain drive/transfer mechanism. It doesn't line up well enough the way I have it and the chain binds up on the sprockets more that I want. I also need to come up with a descent tensioner for the chain. Problem is, I'm using the same mounting screws from underneath that attach the steering cross link and Bellcrank system.
Jim
Old 08-08-2016, 06:38 PM
modelman modelman is offline
Good start jim!! Where do you find these metal toys?
Old 08-08-2016, 07:02 PM
Rvjimd's Avatar
Tom, thanks.
I found one dump truck at the pike steam show a few years ago and I found one local here at a antique/consignment shop. My dragline came from a local diecast toy store, it was a lucky find.
I'm hoping to find something at the steam show this weekend.
Jim
Old 08-27-2016, 05:39 PM
Rvjimd's Avatar
Going a different direction with the drive train and suspension on the truck. Here is the proto rear axel ready for milling hex on the ends to fit my wheels.
Jim
Old 08-27-2016, 06:25 PM
Jim-what,s your plan on milling the hexes on the ends? I have been thinking about doing this on my dragline walking system but I don't know how to do it and keep the ends matching without an indexer. (I think that is what I need), but I am just in the thinking part right now. May never happen.
Old 08-27-2016, 07:03 PM
Rvjimd's Avatar
Tom, I found two hex nuts that fit close onto the shaft. I drilled through the flat of the nuts and taped them for set screws on opposite side of each nut so I can attempt to evenly tighten the nuts just to try and keep them reasonably centered on the shaft.
I laid the assembly on the surface plate as I tightened the nuts to keep them parallel, although for my case I don't think it would really matter that the hex on one end is in the same plane as the other end.
Then I simply laid the shaft with nuts attached into the mill vise and milled one flat, then rotated to the next flat on the nut.
Jim
Old 08-29-2016, 10:57 AM
Rvjimd's Avatar
Once I figured out how to do the hex I decided to go big. So, I'm making hubs for the wheel with the hex and a flange that looks like a brake rotor. That pulls up against the inside spokes of the wheel with a 6-32 cap screw to keep it parallel with the wheel. Then I drill the inside of the hub to fit a 1/4" steel axel.
Hex milled on the mill using a slip fit nut attached to the round. Then moved to the lathe to turn the rest.
Turned down and parting it off here.
Jim
Old 08-30-2016, 12:04 AM
Independant suspension, coilovers, alloy super-singles, brake disks... somebodys building a Sports Dump Truck!
Looking really cool so far. I can't wait to see how it turns out.
Old 08-30-2016, 06:42 AM
Rvjimd's Avatar
ya, you might get that impression huh? the coils and independent suspension is going away and the disc brakes which probably aren't typical are mostly for my machining experience/practice and to try and give support to the plastic wheel. I plan to make my own rims if I ever get this sucker powered up and working with the "borrowed" plastic.
Jim
Old 08-31-2016, 12:29 PM
Jim-looks like you, the mill and lathe are getting along nicely. They can be lots of enjoyment and you can make about anything your mind can come up with. However, after cranking those handles for a long time it can get boring. That's why new projects are important. Truck is coming along good!!
Old 09-05-2016, 11:19 AM
Rvjimd's Avatar
Trying to figure out how to make the mesh a bit more/easier to adjust.
Jim
Old 09-20-2016, 11:45 PM
Without knowing your plan for that axle, but thinking about gear mesh. It looks like you're thinking both bushing and bearings.
Would it work to thread half of the axle shaft so that you could run 2 thin plain nuts in a jam configuration on the right of that picture where the bearing is currently, to pull the mesh tight. Maybe do that on both sides for an easy adjustment of mesh and backlash.
Or a more difficult but much cleaner install could be milling a flat inside the pumpkin where the base of the crown gear sits, so that you can just shim the crown gears together. It'd be more annoying to set up, but your axle tubes could be thinner and it won't weaken the shaft like threading would.
Old 04-30-2017, 09:23 AM
Rvjimd's Avatar
Dump Truck Conversion Take Two!
Got myself a donor with solid diff/axels and started over on the dump truck.
Here are the leaf springs and shackle so far. Leaves are made from steel strap and shackle parts are plastic chain links and aluminum channel.
Springs are about 3.5" eyes, might change once I get further into it and see how it sits.
Planning to use brass tube for the pivots
One shackle...
Stay tuned....
Jim
Old 04-30-2017, 02:10 PM
Rvjimd's Avatar
Going to try a single helper and using heat shrink as a keeper
Axel mounted
Now I need to figure out how to solve the wheel and hex size mismatch. I have some wheels I plan to try but the hex is smaller than this one here.
Jim
Old 04-30-2017, 05:37 PM
Aww, no more sports dump truck?. Looks like a good restart!
I like the spring hangars, but that shackle may limit the suspension movement. If you want more suspension articulation later, you can often swap the brass leaf bushings for a piece of silicone fuel tube/aquarium air line.
The rear pinion angle looks good, how does everything feel with some weight on it?
What size hexes do your new wheels have?
