Old 12-01-2017, 09:07 PM
DrDiff DrDiff is offline
DrDiff is on a distinguished road
Default Beier sound controller and light setup
Rather than risk my rig with a tamiya MFU burning up my LiPo batteries I chose to go with a Beier setup as it has low voltage cutoff. I will be posting pictures as my build progresses.
Dean Cory
Knox, IN
Old 12-02-2017, 02:57 AM
gismow's Avatar
gismow gismow is offline
gismow is on a distinguished road
Default Re: Beier sound controllerand light setup
Hi Dean,
great choice, all my Trucks do have this Module and it is absolute fantastic.
Greetinx
Peter
Old 12-02-2017, 06:59 PM
The Beier USM RC2, LS-4R-10W-50, 4 Ohm, 10 Watt, 50 x 50 mm Loud Speaker and Housing
Dean Cory
Knox, IN
Old 12-02-2017, 07:11 PM
I also have:
Volume Control Pot, 2 Additional Servo patch cables, Terminal Clamp for lights, EXM2 Extension module Extension Data cable K-USB-2, and a battery Y cable.
Dean Cory
Knox, IN
Old 12-02-2017, 07:21 PM
gismow's Avatar
Hi Sean,
full feature package...
What kind of truck do you want to set up with this and which features do you want to implement?
Greetinx
Peter
Old 12-03-2017, 09:12 PM
I am going to setup my Freightliner Cascadia Evolution. I want it to have startup and when the engine fires the running lights come on. Turn signals Engine sounds, Low Beam Headlights, High Beam Headlights, Fog Lights, Stop Lights and Reversing Lights Couple and uncuple. Horn
Dean Cory
Knox, IN
Old 12-03-2017, 09:16 PM
USM-RC2
Bottom of USM-RC2
Dean Cory
Knox, IN
Old 12-03-2017, 09:18 PM
Press in Light Harness If you have an Extension Module EXM2, you will want two of these
Dean Cory
Knox, IN
Old 12-03-2017, 09:20 PM
Power Harness
Dean Cory
Knox, IN
Old 12-03-2017, 09:22 PM
USB Communication Harness. So you don't have to pull the memory card.
Dean Cory
Knox, IN
Old 12-03-2017, 09:25 PM
Volume control pot
Dean Cory
Knox, IN
Old 12-03-2017, 09:31 PM
Extemsion Module EM2 and Harness.
Dean Cory
Knox, IN
Old 12-03-2017, 09:33 PM
Test Setup
Dean Cory
Knox, IN
Old 12-03-2017, 09:41 PM
OK I know that the Sound Unit goes between the output of the RX and the Steering Servo and ESC. I am confused as to where the jumpers from the RX to the Sound Unit plug in at.
Dean Cory
Knox, IN
Old 12-04-2017, 12:49 PM
gismow's Avatar
Hi...
on the upper right you connect the module to the receiver resp. other modules.
From top to bottom:
- Prop#1 upper: Cable from the receiver (gas)
- Prop#1 lower: Cable to the ESC
- Prop#2 uppper: Cable from the reveiver (steer servo)
- Prop#2 lower: Servo cable
- Prop#3: Optional : If you want to want to use e. g. the EKMFA
- Prop#4: Optional
The cabeling for Prop#2 is only needed if the turning lights should be turned off by the steering or if the curve lights (correct word ?) should be used.
Greetinx
Peter
Old 12-04-2017, 09:08 PM
Originally Posted by gismow View Post
Hi...
From top to bottom:
- Prop#4: Optional
Yes, I want Turn signals to function.
Dean Cory
Knox, IN
Old 12-05-2017, 06:47 PM
I am starting to think that to be able to use all channels on my Taranis Plus, I have to use the ECM-2. I purchased the ECM-2 as well as my USM-RC-2. I understand that the USM-RC-2 can detect the motor signal coming out of the RX into the ESC.
This will give me the same number of channels as my RX for sound and control. I have both a 6 channel RX and an 8 channel RX.
This leads to questions...
How do I tell the USM-RC-2 that I want Digital mode?
For example for the head lights, can I string two bulbs on a single output?
Dean Cory
Knox, IN
Old 12-23-2017, 01:36 PM
gismow's Avatar
Hi Dean,
here you can activate the digital mode:
Greetinx
Peter
Old 12-04-2017, 01:15 AM
Kingcam2's Avatar
Kingcam2 Kingcam2 is offline
Location: Mount Evelyn/Lilydale Area, Melbourne, Victoria, Australia, 3796
Kingcam2 is on a distinguished road
HI DrDiff
There is some helpful video Tutorial for the USM-RC2 on Beier youtube channel.
https://www.youtube.com/user/BeierElectronic
Regards Cameron.
Sees no evil, Hears no evil, Speaks no evil
Old 12-04-2017, 09:05 PM
Test setup.
The Taranis is an airplane radio. Meaning throttle is on CH3. Beier USM-RC-2 is setup for surface radio so they expect throttle to be on Ch2. So to solve this I had to pull signals from Rx Ch3 and put them into the USM-RC-2 Ch2. Now the throttle is on the throttle stick and steering is on the other stick. Since my Freightliner has the stock three speed transmission I want to put it on ch Ch3 and have Ch2 for lights and sound. I may have to delete the shifting and lock it into Low range so I can use Ch3 for sound and lights on Ch4.
A sharp eye will notice the Airplane Brushless ESC and Motor.
Dean Cory
Knox, IN
