Old 03-13-2018, 03:56 PM
gismow's Avatar
gismow gismow is offline
Default Mercedes Actros SLT
Hi...
3 Years ago I started to plan the build of a Mercedes SLT Truck
Here's a sample picture:
The build started in October 2015, I bought a Actros 1851 Kit and some additional parts like axles and frames.
The plan was to create the most parts on my own.
Greetinx
Peter
Old 03-13-2018, 03:59 PM
gismow's Avatar
Default Re: Mercedes Actros SLT
My first milestone was to correct the measures of the stairs. I don't know why, but the stairs are different.
The final version:
Greetinx
Peter
Old 03-13-2018, 04:09 PM
gismow's Avatar
Next milestone: The Side plates of the technical tower
Let's start with the left side...
Copy the line of the cabin
Cutting the styreen plate following the line
Follow up the lines of the cabin
Cutting the outer lines
Adding an angle at the top to follow the cabin
Lower the middle part
Adding a double layer at the top to get the rounding
Last step, a border
Greetinx
Peter
Old 03-13-2018, 04:14 PM
gismow's Avatar
The right side in pictures:
Both
75 EUR saved...
Greetinx
Peter
Old 03-13-2018, 04:16 PM
gismow's Avatar
Next step, the frame
Fenders added
Greetinx
Peter
Old 03-13-2018, 04:19 PM
gismow's Avatar
The exhaust
Two holdings
Final
Some more EUR saved...
Greetinx
Peter
Old 03-13-2018, 04:29 PM
gismow's Avatar
A storage box hiding the charger contacts and the On/Off switch
Two holdings added
Greetinx
Peter
Old 03-13-2018, 04:36 PM
gismow's Avatar
The adblue Tank
The holdings
Finished...
Greetinx
Peter
Old 03-13-2018, 04:38 PM
gismow's Avatar
The rear end, it was made with CNC by a forum colleague
Greetinx
Peter
Old 03-13-2018, 04:44 PM
gismow's Avatar
The rear light holdings slightly modified
Greetinx
Peter
Old 03-13-2018, 04:49 PM
gismow's Avatar
Next step, the working area with a small ladder
Greetinx
Peter
Old 03-13-2018, 04:59 PM
gismow's Avatar
The next huge milestone: The tower
To join the parts of the tower I decided to create "shoes" for the connection points. They have more stability.
Placed on the frame
The holdings for the side plates
Greetinx
Peter
Old 03-13-2018, 05:02 PM
gismow's Avatar
Some air pressure tanks
Greetinx
Peter
Old 03-13-2018, 05:08 PM
gismow's Avatar
The diesel and hydraulic oil tanks
Two additional storage boxes (one will be modifed later) and one removed again.
The boxes were planned to have the electronic parts, but that decission was changed later.
Greetinx
Peter
Old 03-13-2018, 05:13 PM
gismow's Avatar
A small step, some working lights
Greetinx
Peter
Old 03-13-2018, 05:16 PM
gismow's Avatar
After some test with the steering and some searches in the internet I decided to lift up the first fender by 5mm so that the tire no longer touches the fender if weight lies on the frame.
Greetinx
Peter
Old 03-13-2018, 05:18 PM
gismow's Avatar
Some small items for the beacon lights
Greetinx
Peter
Old 03-13-2018, 05:24 PM
gismow's Avatar
The oil cooler
The air pressure tanks are slightly modified
Greetinx
Peter
Old 03-13-2018, 05:28 PM
gismow's Avatar
Front and rear lights from Servonaut:
Greetinx
Peter
Old 03-13-2018, 05:33 PM
gismow's Avatar
Next step with a lot of work, I wanted to change the mirror holdings. The solution of Tamiya is a real joke.
So I started to model some brass.
Greetinx
Peter
