Old 05-25-2011, 08:51 PM
texken's Avatar
texken texken is offline
texken is on a distinguished road
Default help on Radio
Need radio, any good input for a radio to run chassis and Crane with one radio??
For my LTM 1030 Truck Crane
TEXKEN
Old 05-25-2011, 09:50 PM
Hanson50 Hanson50 is offline
Hanson50 is on a distinguished road
Default Re: help on Radio
Texken
I am working on the Potain crane build. I have a Polk Tracker III 8 Chanel Radio, PMD sell it modified for truck, for $299.00. I got mine direct from Polk for $99.00 It is a basic flying radio, but set up for surface frequency. I will be using 3 Receivers, but using one channel with a 3 way toggle switch to control a rc switch to activate different set of functions. ( ie. Lower crane function, and jib open and close functions.) You can PM Me for clarification.
Paul H. Hanson
Owner must be present to win.
Old 05-25-2011, 11:35 PM
Modified how?
I've been using the Polk radio for 3-4yrs now, works very well.
Old 05-26-2011, 05:09 AM
Rebekah_harper Rebekah_harper is offline
Rebekah_harper is on a distinguished road
I would recommend this idea.
a Spektrum with model memory.
the model No's are reciever specific. not sure how it works but I know that when you change model No you also change reciever. This will allow you to run two completely seperate circuits so there is no need for the slew ring to have contacts or have cables running up it. plus you can have your full range of channels.
I am building a LTM 1250. and this is what I will be doing with a DX8
Becky
Old 05-26-2011, 05:51 AM
texken's Avatar
thank for input.
TEXKEN
Old 05-26-2011, 07:58 AM
Lil Giant asked how the PMD Polk was modified?
I don't even know if it is modified,(I would hope theirs not a $200.00 markup.) The only thing I see wrong with mine is one joystick is not spring return
Paul H. Hanson
Old 05-27-2011, 05:19 PM
pumptech's Avatar
pumptech pumptech is offline
Paul H. Hanson
I have a 4 channel Tactic transmitter ,left joystick was not spring return,took the transmitter apart ,removed the stop for the joystick, now it has spring return,I suppose it can be done with different makes and models.
Old 05-27-2011, 06:13 PM
texken's Avatar
Thank you input.
What about batteries??
The 7.2 are too long.
I need some 3/3 " for my small space.
Any help.
TEXKEN
