Old 08-24-2010, 12:54 PM
will916691 will916691 is offline
will916691 is on a distinguished road
Default how do you lock the rear
How are you guys locking the rear axil in you trucks? I need to lock one or both since I run it in grass but I want to be able to take the locker out if I dont like it
Thanks
Will
Old 08-24-2010, 01:12 PM
MadMax
Guest
Posts: n/a
Default Re: how do you lock the rear
look for parts sprew G out of the Jeep Wrangler.
Old 08-24-2010, 01:23 PM
Or you can take apart the diff, remove one of the spider gears and place it in between the other two. Might have to work it down in a tad to re-assemble. BAM! Instant free reversible locker.
Old 08-25-2010, 01:07 PM
thanks guys I will try the spider gear and see if that works
Will
Old 08-25-2010, 01:29 PM
Here's a picture, although the guy used a 4th gear, you can use one in it. On Scale4x4 and RCC people having been using this method for years.
Old 08-27-2010, 10:40 AM
diesel950 diesel950 is offline
diesel950 is on a distinguished road
i locked my front diff like that and broke the carrier for the spider gears
the shaft actually came out of the diff casing!
so now it is really locked with 6 gears instead of 3.
Old 08-27-2010, 10:47 AM
Now that's locked!
Maybe it was a bad carrier, I can't think of hearing any breakage with this mod.
Old 08-27-2010, 11:35 AM
I just locked it works good no more getting stuck in the grass
Old 08-27-2010, 11:34 AM
Stuff's Avatar
Stuff Stuff is offline
this is how i locked all of my axles. cept i didnt have spare gears so i just moved one to be in between the others and it works nice. true its a bit to take it out but it works and doesnt wreck my internals!
my YouTube is -
Subscribe!!
My Facebook -
Old 03-28-2012, 05:58 PM
pumptech's Avatar
pumptech pumptech is offline
Starting on my King Hauler,first king build for me. Tried this method ,seems like it going to work.
Old 03-28-2012, 07:15 PM
chaseracer's Avatar
the extra gear works well used it for years in crawlers with tlt axles.. but silly putty works best if want a locked diff that becomes limited slip just before breaking just pack the gears full of silly putty close it up remove the extra that squishes out and good to go.. great locked preformance but with give under too much pressure.
Old 08-30-2010, 07:46 AM
i think mine broke with a bit of force.
but then again i am usually dragging 3 trailers
sometimes a lot more.
Old 08-30-2010, 09:04 AM
CorbettTrailers's Avatar
CorbettTrailers CorbettTrailers is offline
CorbettTrailers is on a distinguished road
I'm a little late. but I locked mine with Freddy's method. I drilled and tapped a hole. It still requires complete disassemble of the axle hosing and differential, but I've had no problems. And this includes hauling the neighbor kids around on my trailers and running in grass. Freddy would prolly be able to tell more. I locked mine right before the Brookville meet in March and I'd have to tear mine apart to remember how to do it. Too many knocks on the Noggin', even with a helmet it still had an effect.
But glad you got it locked!
Old 08-30-2010, 11:45 PM
CustomRCmodels's Avatar
CustomRCmodels CustomRCmodels is offline
CustomRCmodels is on a distinguished road
I lock my diff’s with hot-melt ( glue-gun ) ,
Since that stuff stays somewhat flexible , it allows some very little movement ,
more like it flexes . With that method I never had any issues , no matter how much I pulled or what ever crazy stuff I do with my trucks .
All these other methods maybe a little to stiff , therefore the one or the other experience some damages upon depending how much torque you apply to your axles .
I would like to find a real super heavy grease , which would act like a limited slip differential , but so far no luck . Everything I came across so far was still to thin .
I been also thinking about using shims in the diff’s , to make everything work , but with a lot more resistance , again , similar to a limited slip differential , but didn’t get to that one yet … to much work , not enough time , ha
Besides , these days I am tending to improve my suspension and add weight to the tires and frame , as long you can keep your tires on the ground , you don’t need no locked diff’s , excepted you drive in very loose ground or sand .
this one here has NO locked diff's and I never got stuck with it !
http://www.customrcmodels.com/Trucks...wd_project.htm
(Wild)-Willy
CustomRCmodels
Old 03-22-2012, 11:39 AM
This is what I was going to suggest with stiff oil. My brother told me about this technique they use with their racing buggy's and trucks.
Try some silicone grease from the plumbers section at Home Depot.
There is a semifluid oil we use on our old Cats to lube the rollers. I think it is known as "00" semi fluid grease.
I have some of that and some Castrol Longtime PD O these greases are like vasalene consistancy.
Another grease to try may be the stuff they use on binocular and camera lenses. That would give a nice slow movement. There are different grades for varying temperatures the binos work at.
Old 03-22-2012, 09:18 AM
OLDPETERBILTLOVER OLDPETERBILTLOVER is offline
OLDPETERBILTLOVER is on a distinguished road
i locked the front drive axle on my king using the spider gear methode and it works wounderful!!!
Old 03-24-2012, 01:15 AM
I've found Shoo Goo to work good for a "limited slip" without being full locking, not so hard on driveshafts.
