Old 09-07-2010, 11:33 PM
CorbettTrailers's Avatar
CorbettTrailers CorbettTrailers is offline
CorbettTrailers is on a distinguished road
Default All About LED's
How about a thread that deals with LED's, like wiring, mounting details, resistors and where to find them. I'm thinking about lighting my truck up but have no idea where to start. I do have the tlu-01 installed and I ordered some LED's for the cab lights, but I'd like to ad some more. Any info would be greatly appreciated.
ECMT Members: Join your Group. Go to your username in the top right corner of the page and click on it. When your profile opens go down to group memberships, Click on East Coast Mini Truckers, The social group will open and scroll down And in the middle it you will see "Join Group" Click on it and then confirm that you REALLY wanna join.
[SIZE="2"]
Old 09-09-2010, 01:41 PM
Default Re: All About LED's
So out of the 25 people that have visited this thread, noone has anything to offer as to info that I need to get some LED's on my truck?
Just something, Anything?
[SIZE="2"]
Old 09-09-2010, 01:48 PM
OK you asked for it duh I don't know hehe I'm in the same boat just be patient grasshopper some nice fellow will come along and help also google may help
Old 09-09-2010, 02:13 PM
I tried google, there's too many darn links. I like reading Novels, not endless Bull****. Lol.
[SIZE="2"]
Old 09-09-2010, 03:12 PM
SonoranWraith's Avatar
It's a dry 115 degrees.
A place I like to buy because they have great variety of sizes:
http://led-switch.com/
I can also obtain them locally at Fry's Electronics so check electrical supply places for those that don't like waiting.
A wizard to help you design your layout:
http://led.linear1.org/led.wiz
The basics are that LED's are lower voltage around 1.5-3.3V. This means they need a resistor to lower the voltage and keep them from blowing out. You cannot hook them direct to your RC battery voltage.
Wire in series is hooking a string of diodes like building a battery pack, positive to negative with 1 positive lead and 1 negative lead out of the array. It is the least amount of wires but the voltage drops across each diode (LED) so it limits how many you can hook together. Wire in parallel is separate wire leads to each diode from the source voltage which would need a resistor for every diode. This might be the simplest but it makes for a lot of wires and the resistors essentially waste your energy stepping the voltage down. The best design is one that keeps the resistors to a minimum and means arrays of diodes in series hooked up in parallel.
Plug some numbers in the wizard link earlier in this post. Source voltage of 7.2V (std 6 cell) 3.0v diode forward, 20 diode forward current, and however many lights you want. Choose wiring diagram because it is pretty well illustrated for non-tech folks. Your array will be displayed.
The same concepts apply whether you are hooking up chicken lights, headlights, blinkers, tail lights, etc. You CAN wire more lights to your MFU. I don't have one, but I have seen it done. Hopefully someone with experience at that will chime in.
Old 09-09-2010, 03:31 PM
Blender's Avatar
Blender Blender is offline
I'm no pro, but I'll tell you what i know. I've never used a tlu-01, but I build my own helicopter blades with LEDs on them to fly at night.
Leds require a specific forward voltage (Vf) to light up. It's usually 2-5 V, but there are some that run on higher voltage. If connected backwards the LEDs won't light up, but they won't be damaged. The current draw is generally around 20mA, but it can vary by color/size/make. Check the datasheet provided by the vendor. There are lots of different size/shapes of LEDs. I usually work with surface mount (SMD) which come in 4 digit size codes (ex. 0603 which is 0.063" x0.031"). Other sizes are 3mm and 5mm round like what's usually at radioshack. Visible angle is another important feature. Some LEDs have very narrow light beams like 20 degrees. That might me fine for headlights, but if you want lights along the side of your trailer something with 130 degree or more would be better.
How i build an array is first select LEDs with a Vf lower than my battery i'm going to use. I use off-the-charger pack voltage instead of the nominal voltage that's printed on the battery pack. A trick i use is to connect various LEDs in series until the sum of the Vfs is about equal or a little higher than the battery voltage. This will let me run the LEDs with no resistor. There is a little risk to this as if my wiring shorts out there will be no resistor to reduce the current. I killed one of my 160mAh lipos when my blade mounted LED/wiring came loose and shorted out the battery pack. The standard/safer method is to use a LED calculator where you type in the Vf, current and battery voltage then it'll tell you what resistor you need. There's also a version that handles multiple LEDs by the same people.
If i want to add a ton of LEDs with all kinds of colors and sizes i break the work into small pieces. Say i'm using a 3S lipo thats 11.1V nominal, 12.4V fully charged. If i wanted eight amber LEDs and the each had a Vf of 3.1 V, I'd make a string of 4 LEDs in series. Then make another string of 4 amber LEDs and connect the two strings in parallel to the battery.
Key features:
Vf Forward Voltage
Size/ mount type
viewable angle
brightness measured in mcd (milli-candela). I like 100-200 mcd
The cheapest LEDs i've found are from china Ive never ordered from SatisTronics personally, but a few of the heli guys have. They are considerably cheaper than Digi Key, Superbrightleds or Allied Electronics. I'd encourage you to order a few and just play around with a soldering iron and a battery. You'll smoke a few LEDs, but they're only a few cents each . I use conductive copper tape and solder to connect SMDs and small wire with headsrink to connect the round LEDs.
Old 09-09-2010, 04:37 PM
Originally Posted by Blender View Post
I'd encourage you to order a few and just play around with a soldering iron and a battery. You'll smoke a few LEDs, but they're only a few cents each.
This is a very good idea. Thanks.
And thanks to everyone else for all the info. This is going to be very useful, exactly what I was looking for.
Thanks Again,
John
[SIZE="2"]
Old 09-09-2010, 04:19 PM
Thorsteenster Thorsteenster is offline
Thorsteenster is on a distinguished road
It's been awhile since I've bought or researched into LED's. I know I posted links somewhere, I'll see if I can dig them up. I had found a great domestic seller for LED's, cheap, bulk and multi packs and fast shipping, and a few good How To:'s for LED wiring.
Call me Thor, it's short for Thorsteenster.
In VA? Check out
Old 09-09-2010, 04:39 PM
Thanks, I'll be waiting to see if you find the links an post them.
[SIZE="2"]
Old 09-09-2010, 04:55 PM
Okay, I guess the pressure's on now.....
In VA? Check out
Old 09-09-2010, 06:02 PM
Ready, Set. . . . . . . .GO!!!!
No hurry really. I was hoping to have some lights for Brookville but it's ok if I don't. I do have the TLU-01 in it now. Figured I'd better start slow and figure out what I'm doing first before I go gung ho. To be honest, it was Rod's White Stretch that did me in. That truck looks awesome. So I figured some lights on my rig would look cool, if I do it right. Now I'm trying to think of an easy way to hook up the trailer lights to what I have.
[SIZE="2"]
Old 09-09-2010, 10:16 PM
Okay, here's what I've found so far. I have probably a couple hundred favorite links from older computers I'll try to look through this weekend if I have more. I think this at Instrctables was the best I found for wiring though.
http://www.instructables.com/id/LEDs-for-Beginners/
And the past few times I've bought LED's I got them here:
http://c-leds.com
This place is great, they have LED drivers, and as well know quite a bit about LED's. They've answered several questions for me via email and as well put together variety packs for me.
Another thought for some of you truckers handy with fine soldering, is SMC LED's. Those are the surface mount ones you find on circuit boards and what not, very small, about the size of a match head. Seems they might be great for running board lights, marker lights, cab lights, all sorts of things that might be lit but not room for a 3mm LED.
Not RC, but here you can get an idea of size and tips for soldering.
In VA? Check out
Old 09-09-2010, 10:25 PM
Thanks Thor. I'll have to read more this weekend.
[SIZE="2"]
Old 09-10-2010, 03:49 AM
Give me a little time and I'll see if I can draw up some actual wiring schematics for you to check out. I'll make a couple different versions. One of a truck without an MFU, one with an MFU, for those wanting to add extra lighting, and one for a trailer.
Old 09-10-2010, 10:00 AM
Nathan, That sounds great. And I will repay you by keeping the knowledge I learn and passing it on to the next newbie that needs the info. Someday, somewhere someone will be in need.
[SIZE="2"]
Old 09-10-2010, 10:02 PM
IDontKnow's Avatar
IDontKnow IDontKnow is offline
IDontKnow is on a distinguished road
Hmmm, somewhere back in this thread it was stated that each LED requires a resistor!
Not True! I have two flatbed trailers each with 10 clearance lights (5 each side) and only 1 resistor.
I have the infrared lighting system from SS-Tronix and the whole thing is powered by a 7.2v pack mounted between the rails. Power comes up from underneath feeds to a 1/2 watt resistor then loops in and out of each led in parralel down the left side and back up the right. Works beutifully using 3mm high brightness orange LED's in chrome bezels.
If I get a chance I will show some pictures of the setup.
Old 09-10-2010, 11:39 PM
roadranger's Avatar
roadranger roadranger is offline
White Line Fever
roadranger is on a distinguished road
IDontKnow, you also gotta tell us where you got the LED's, and especially where to get the chrome bezels. I can only find black bezels...
WILDCAT T&C
Jim B.
Colorado Springs
Old 09-11-2010, 12:15 AM
Corbett, no problem at all. I'll try and get something up by the weekend.
There are a couple ways to wire LEDs. If you wire them in parallel, then each LED definitely needs it's own resistor. If you wire them in series, then you can get away with using one resistor for each set of LEDs in series.
Out of the two methods, I wire LEDs in series. The reason being that it is a more efficient circuit and the total current draw will be less then a parallel circuit. I'll go more into depth with this explaination as soon as I get some drawings whipped up!
Old 09-12-2010, 08:35 AM
IDontKnow's Avatar
I am sorry, but you are incorrect there. If wiring in parallel you can do it with only one resistor as long as the wattage is high enough as in 1/2 to 1watt resistors.
10 LED's on my flatbeds both wired in parallel with 1 resistor and been working perfectly for the last 6 months! No overheating of anything all LED's are bright and uniform in light output. Current draw? Minimal Charge the 7.2 volt 4000mAH battery about once every two to three months. The resistor size is 330ohm 1/2 watt
Will post details on the Bezels and LED's when I find it again
Old 09-13-2010, 03:16 AM
The big reason I suggest running a resistor on each LED in parallel is simple. No two LEDs are identical in their construction, which basically means the resistance of each LED, even from the same production batch, varies. Why is this a problem? Because in a parallel circuit the current will always take the path of least resistance. Or in other words, the LED that happens to have the least resistance. What happens is that LED will be subject to higher current flow then it is rated for. The more LEDs you have in your parallel circuit, the worse this problem becomes. Remember in parallel circuits that voltage stays the same to all loads. Current, however divides across them. This is also why I suggest a series circuit. In series circuits, current remains the same across all loads, regardless of each component's resistance measurement. The voltage divides.
To safely run multiple LEDs in parallel, each really should have it's own resistor, or your weakest LED will be have the most current flowing through it. Yes, you can get away with one resistor for multiple LEDs in parallel, but is not optimum for the life or performance of the LEDs.
In regards to current draw, parallel circuits are additive. It may not sound like a huge deal when you are running ten LEDs and each only draws .020 amps, but if you have 100 LEDs on a truck and trailer combo, that is suddenly a 2 amp draw! That will start to be a noticable draw on your battery. A 4000 mili amp pack will be dead in two hours with 100 LEDs, wired in parallel, alone. That does not account for any current draw from the motor, while driving. If you are one of the guys who likes to run more then 100 LEDs, it is definitely something to consider.
